Where does TMRh20 RF24 fit?
I am wrestling with the nRF24L01_Product_Specification_v2_0 and starting on page 46 there is a list of commands by which to communicate with the chip. I think these are contained in SPI.h. I have been using TMRh20 RF24.h.
Is TMRh20 RF24 an Arduino-language package which uses the SPI package while keeping the programmer away from the nuts and bolts of it?
Basically answer is YES - see http://tmrh20.github.io/RF24/ and RF24 Class Reference and see you can instantiate an RF24 and give the SPI speed in MHZ as parameter eg: BCM2835_SPI_SPEED_8MHZ
You should probably start on page 1, so that by the time you get to page 46, you understand the material there. Usually works for me.
PaulS: You should probably start on page 1, so that by the time you get to page 46, you understand the material there.
I only said that the [u]list[/u] starts on page 46 :)
Being that 'TMRh20 RF24' is an abstraction getting the programmer away from the nitty-gritty of 'SPI', there is no need to declare it in a program (as long as you declare 'RF24' ). I originally assumed it was always declared because you need it for 'Serial' but [u]not so[/u]! I commented the declaration of 'SPI' out of my current project and that made no difference to the debug calls to 'Serial.println()' etc.
