Where have I gone wrong with my int maths?
For some reason the following equation isn't behaving as it should within my program:
gyroang_z= gyroang_z + gyro_z*(duration/1000000);
where gyroang_z and duration are stored as long and gyroz is an int.
Duration is the sampling time which has been worked out by:
now = micros();
  duration=(now - last);
  last= now;
where now and last are unsigned longs. So the variable duration is in microseconds, hence divided by 1,000,000 in the above equation. Gyro_z has typical values of 1-1000
None of the values i'm getting look right, I've checked the outputs of gyro_z and duration and they result in a fine answer when done manually, so I guess something must be overflowing, but how?
Edit: the entire code looks like this:
#include <Wire.h>
#define DEVICE_GYRO (0x68)    //device address
#define DEVICE_ACC (0x53)
#define TO_READ (6)        //num of bytes we are going to read each time (two bytes for each axis)
byte buff[TO_READ] ;    //6 bytes buffer for saving data read from the device
char str[512];                      //string buffer to transform data before sending it to the serial port
int gyro_x_off, gyro_y_off, gyro_z_off;
unsigned long now;
unsigned long last;
long duration;
long gyroang_z;
//Function Definitions
void gyroraw(int & x, int & y, int & z)
  int regAddress = 0x1D;    //first register
  readFrom(DEVICE_GYRO, regAddress, TO_READ, buff);
  x= (buff[0] << 8) | buff[1];
  y= (buff[2] << 8) | buff[3];
  z= (buff[4] << 8) | buff[5];
void accraw (int & x, int & y, int & z)
  int regAddress = 0x32;    //first register
  readFrom(DEVICE_ACC, regAddress, TO_READ, buff);
  x= (buff[1] << 8) | buff[0];
  y= (buff[3] << 8) | buff[2];
  z= (buff[5] << 8) | buff[4];
void writeTo(int device, byte address, byte val)
  Wire.beginTransmission(device); //start transmission to device
  Wire.write(address);        // send register address
  Wire.write(val);        // send value to write
  Wire.endTransmission(); //end transmission
  } // end of writeTo
void readFrom(int device, byte address, int num, byte buff[])
  Wire.write(address);        //sends address to read from
  Wire.requestFrom(device, num);    // request 6 bytes from device
  int i = 0;
  while(Wire.available())    //device may send less than requested (abnormal)
    buff[i] = Wire.read(); // receive a byte
    i++;
  }  // end of readFrom
//Begin program
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
  //GYRO LAUNCH
  writeTo(DEVICE_GYRO, 0x3E, 128);
  writeTo(DEVICE_GYRO, 0x16, 24);
  //ACC LAUNCH
  writeTo(DEVICE_ACC, 0x2D, 0);
  writeTo(DEVICE_ACC, 0x2D, 16);
  writeTo(DEVICE_ACC, 0x2D, 8);
  writeTo(DEVICE_ACC, 0x31, B00001011);
  writeTo(DEVICE_ACC, 0x2C, B00001111);
  readFrom(DEVICE_ACC,0x2C,1,buff);
  int value;
  value=(buff[0]);
  Serial.print(value);
  //GYRO ZERO
  for(int i=0;i<500;i++)
     int x,y,z;
     gyroraw(x,y,z);
     gyro_x_off+=x;
     gyro_y_off+=y;
     gyro_z_off+=z;
     delay(10);
     gyro_x_off=abs(gyro_x_off/500);
     gyro_y_off=abs(gyro_y_off/500);
     gyro_z_off=abs(gyro_z_off/500);
     sprintf(str, "%d, %d, %d",gyro_x_off,gyro_y_off,gyro_z_off);
     Serial.write(str);
     Serial.write(byte(10));
}  // end of setup
  now = micros();
  last= now;
  //Serial.print(duration);
  int gyro_x, gyro_y, gyro_z;
  int acc_x, acc_y, acc_z;
  gyroraw(gyro_x, gyro_y, gyro_z);
  accraw(acc_x, acc_y, acc_z);
  gyro_x=(gyro_x-gyro_x_off)/14.375;
  gyro_y=(gyro_y-gyro_y_off)/14.375;
  gyro_z=(gyro_z-gyro_z_off)/14.375;
  //we send the x y z values as a string to the serial port
  sprintf(str, "%d %d %d",gyro_x, gyro_y, gyro_z);
  Serial.write(str);
  Serial.print(" Z angle:");
  Serial.print(gyroang_z);
//  //It appears that delay is needed in order not to clog the port
  delay(10);
}  // end of loop
if "duration" is less than 1000000 the integer division (duration/1000000) will be always 0 (because the result of an integer division is not automatically converted in a float value).
You could modify the order of operations, if you are sure that (gyro_z*duration) does not exceed the maximum value of a long variable:
gyroang_z= gyroang_z + (gyro_z*duration)/1000000;
Thank you ea123. Gyro_z * duration may well sometimes be less than 1,000,000 also. Does this mean that I can't avoid having to use duration as a float here?
in this case is it correct that the resuls is added to an integer value (gyroang_z) that can only increment 1 by 1? Maybe you should consider to convert gyroang_z as well to float.
If I made gyroang_z and duration floats then would (gyro_z*duration)/1000000 be exectuted as a float even though gyro_z is an int? What are the rules for this?
No, but (gyro_z*duration)/1000000.0 would be.
Is it always that an int*float = int then?
Do you think what i've done (with your suggestion of 1000000.0) is the best way to do that calculation Paul?
No. int * float is a float. The result is then stored somewhere, which influences the result.
Best? I don't know. Workable? Yes.
Ah, so (gyro_zduration)/1000000 where gyro_z is an int and duration is a float would first return a float from the bracketed operation (intfloat) and then again return a float from float/int?
Yes, but, to make it easier to understand, the constant should be a float, too.
