where I can find the hex file?
Hi
I do a sketch , where I can find the file .hex?
I want program the micro with avrstudio
thanks
Open the IDE preferences, then select verbose mode.
When you compile or upload ( whatever option you select ), it will display the path to the temporary folder.
The output window should finish with something like this:
C:\Users\Elvis\AppData\Local\Temp\build8351408690549800379.tmp/pun.cpp.hex
Binary sketch size: 8,864 bytes (of a 258,048 byte maximum)
This is on windows, I presume the other platforms are the same.
thanks
now I try!
C:\Users\Elvis\ ...
Elvis has returned!
