Hello, I will like to dimmer a led light which it works with 24v. Then I bought this PCB. But I don't know how I have to connect car cables on it.
It is for arduino can controller the power of led voltage with PWM pins...
Thanks..
Thanks..
I assume the wires into the two way connector are the power supply and wired correctly (I cannot see any polarity markings).
If so, it appears that the +Ve is common to one of the two connectors for each output. This is connected to the +Ve of your lights. The -ve side goes to the other side and to the mosfet which will then switch to ground.
This is all without knowing the specifications of the particular board.
Weedpharma
Hi, connect to the site you bought it off and look at the spec and info sheets they SHOULD have available.
Tom.......... ![]()
