Does anybody know where this object "ArduinoCloud" is instantiated and from what class?
As there are no documentation at all about what are the services this object offers, I would like to know at least, what piece of code could I inspect to determine this.
The most obvious answer would be that "ArduinoCloud" is instantiated from the "ArduinoIOTcloudClass" class. but, I can't find where this instantiation is made. And in the "ArduinoIOTcloudClass" class there is no "begin()" method....
UAU!!!!
I am trying to figure out this for a long time!!!
Thanks a lot!
I wonder how did you find this.......
Anyway, I'll keep your contact.... Whenever I have a question I will ask you directly... eheheh
It was not too difficult to find, I googled ArduinoCloud.begin to go to the right GitHub repo and then did a search for ArduinoCloud in that repository. Once I saw the line with extern I knew the type and then it was just a matter of going to the class, usually those variables are instantiated at the end of the .cpp, which was the case.
