For some reason this variable got corrupted (Windows 10):
runtime.tools.openocd-0.9.0-arduino5-static.path
in C:\Users\xxx\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.13
Where is it defined?
This was caused by a bug in the Arduino SAMD Boards 1.6.13 release. I have submitted a pull request to get this fixed. You can see the necessary change here:
So you have two options:
Option 1 (fix the bug):
tools.openocd.path={runtime.tools.openocd-0.9.0-arduino5-static.path}
to:
tools.openocd.path={runtime.tools.openocd-0.9.0-arduino6-static.path}
tools.openocd-withbootsize.path={runtime.tools.openocd-0.9.0-arduino5-static.path}
to:
tools.openocd-withbootsize.path={runtime.tools.openocd-0.9.0-arduino6-static.path}
Option 2 (revert to Arduino SAMD Boards 1.6.12)
Hi pert, I modified the file (there is also a second instance further down from the line you cited) and it seems like it is back to normal. Thanks!
Thanks for pointing out the one I missed! I have updated the pull request and my instructions above. Glad to hear you were able to fix the problem!
