A recursive grep shows that there exists the declaration "extern void setup( void ) ;" in the Arduino.h file. Other files have the same declaration. But nowhere can I find where setup() actually exists as lines of code. Any clues?
You create the setup() function, There are no lines of code until you create the function in your .ino.
Arduino supplies the main() function.
Have a look at main.cpp down in the cores directory.
You will find the main() function that calls you setup() function then has a for loop
that calls your loop() function.
--- bill
setup and loop are in "arduino/hardware/arduino/cores/arduino/main.c"
#include <Arduino.h>
int main(void)
init();
#if defined(USBCON)
USBDevice.attach();
#endif
setup();
for (;;) {
loop();
if (serialEventRun) serialEventRun();
return 0;
If you want to avoid the "setup" and "loop" foolishness, simply use this as a code skeleton:
int main (void)
init (); // setup timers, interrupts, etc... (necessary)
Serial.begin (baudrate); // if needed
normal C and C++ code goes here as usual
while (1); // last line of your code - necessary
Or if your code needs to run in an endless loop:
int main (void)
while (1) {
Hope this helps.
