My understanding of this loop is, if the prior reading of the pot is not = to or +/- 1 of the current pot reading, then there must have been a change, so send the midi command and update the last value read.
However, all I get is a constant stream of midi signals all with the current pot value.
Where is my logic wrong?
edit: I realized it right after I posted it... I suppose I am continuously setting lastPotValue to 0 therefore triggering my if statement every loop. I moved it to global and it appears to work now ![]()
#include <frequencyToNote.h>
#include <MIDIUSB.h>
#include <pitchToFrequency.h>
#include <pitchToNote.h>
// First parameter is the event type (0x0B = control change).
// Second parameter is the event type, combined with the channel.
// Third parameter is the control number number (0-119).
// Fourth parameter is the control value (0-127).
// controlChange(0, 10, 65); // Set the value of controller 10 on channel 0 to 65
void controlChange(byte channel, byte control, byte value) {
midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
MidiUSB.sendMIDI(event);
int lastPotValue;
int potValue = analogRead(A0);
if (lastPotValue != potValue && lastPotValue != potValue +1 && lastPotValue != potValue -1){
controlChange(0, 50, potValue);
lastPotValue = potValue;
