I do not see where the Signal Pin is located on the Fotek SSR-40. Can someone please explain how the both work exactly the same with the Arduino with two different setups?
My bad, I meant 120V pump. I do not have the link. I will be borrowing it from a friend to do test on. I figured for 120V pump the 5V relay in the guide was not sufficient.
30x120= 3600watt. So what is it.
A 20watt pump is the size of a fist.
A wheelbarrow is needed for a 3600watt pump.
omikolaj:
5volt is the voltage needed for the relay coil.
That 5volt can come from the Arduino.
The relay contacts that switch the pump have nothing to do with that.
A blue sugar-cube relay can be used for a 20watt pump, but not for a 3.6kW pump.
Same for the Fotek.
Beware of fake ones, so that 40A rating should be taken with a grain of salt.
The fake ones also seem to have trouble with 5volt logic from the Arduino.
An SSR can be controlled by an Arduino pin directly. +input to I/O pin, -input to Arduino ground.
Leo..
I need to be able to turn it on and off depending on the soil moisture. So the smaller relay will definitely work. I thought it was going to be much bigger pump. Is it safer/better to use the Fotek or in this case it doesnt matter?
