I'm testing a sketch as the code attached, the Serial Monitor shown: 'Enter setting mode fail' ...
My question is where the words 'Enter setting mode fail' text come from, there is nothing like it in the sketch.
#include <SPI.h>
#include "mcp_can.h"
// Configuration //
// CS pin for CAN bus shield.
// The default pin depends on the shield's version:
// - 1.0: digital pin 10
// - 1.1 and newer: digital pin 9
const int CS_PIN = 9;
// Serial port data rate
const long SERIAL_SPEED = 115200;
// CAN bus data rate
const byte CAN_SPEED = CAN_125KBPS;
MCP_CAN CAN(CS_PIN);
unsigned char len = 0;
byte buffer[8];
//// Serial.begin(SERIAL_SPEED);
byte canSpeed = CAN_SPEED;
while (CAN.begin(canSpeed) != CAN_OK) {
delay(100);
if (CAN.checkReceive() == CAN_MSGAVAIL) {
CAN.readMsgBuf(&len, buffer);
Serial.print("FRAME:ID=");
Serial.print(CAN.getCanId());
Serial.print(":LEN=");
Serial.print(len);
char tmp[3];
for(int i = 0; i<len; i++) {
Serial.print(":");
snprintf(tmp, 3, "%02X", buffer[i]);
Serial.print(tmp);
Thanks
Adam
