Where to buy 4051 Multiplexer?
Where did you get yours? I bought a few wrong ones that have tiny pins that don’t fit. How can you tell from the name or the spec that it will fit into a breadboard?
My search has turned up these results. The price is anywhere between $0.50 - $4.10.:
HEF4051BP at newark.com
http://www.newark.com/jsp/displayProduct.jsp?sku=10WX5446&CMP=KNC-G10000679&HBX_OU=50&HBX_PK=HEF4051BP
NTE4051B at newark.com
http://www.newark.com/jsp/Semiconductors+&+Prototyping/Logic,+Standard/NTE+ELECTRONICS/NTE4051B/displayProduct.jsp?sku=31C4074
MAX4051CPE+ at maxim
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1352/t/or
CD4051 at jameco.com
http://www.jameco.com/webapp/wcs/stores/servlet/CatalogSearchResultView?langId=-1&storeId=10001&catalogId=10001&searchType=m&searchValue=4051&categoryId=104210
I would like them soon, and I’m located in the United States. Any advice would be great.
You’re looking for the Package…
DIP or PDIP will fit a breadboard.
Save yourself some money too… Go here and pick the exact part number you want (Page 17):
http://datasheets.maxim-ic.com/en/ds/MAX4051-MAX4053A.pdf
Then go here and ask Maxim to send you a few samples:
:slight_smile: Thanks for the advice! I’ll try MAX4051CPE+.
I also found this at Tom Igoe’s site: “DIP (dual in-line package), PDIP (plastic DIP), and SPDIP (skinny PDIP) packages typically have the pins spaced 0.1 inches apart, and are convenient for the breadboards we typically use in prototyping”
http://www.tigoe.net/pcomp/pic/pic-intro.shtml
Yes, and those called SOIC or SMD are the ones to avoid, they are for surface mounting
