Sorry if this is a stupid question, but where would I find IR codes to use with a library like IRlib2 or IRremote, without using an IR reciever? For instance, I have an LG TV that uses NEC codes, but where would I find a list of them in a format I can use on an Arduino?
Find IR codes is one of many sites found with a search for "lg tv ir codes".
groundFungus:
I found that site when I was searching, but how would I convert the codes into the hexadecimal format for the IRlib2 or IRremote libraries?
Look at the examples that come with the IR libraries. There are several such as IRanalyze, IRrecord, etc., that will simply hook up a receiver and display on the monitor the code received. Works with any remote. Program it yourself.
DKWatson:
I’m asking how to do it without a reciever. I don’t have the remote.
You might find the codes you need on the LIRC site.
FWIW I also have an LG TV and for my project used the codes found on that site. I wrote a header file with the following:
const long PRE_DATA = 0x20df0000; // prefix for remote command
enum COMMAND {
up,
down,
left,
right,
ok
int tv_codes[] = {
0x02FD, // up
0x827D, // down
0xE01F, // left
0x609F, // right
0x22DD // ok
Commands are sent to the TV with the function:
sendCmd
Send passed commend to IR reciever.
void sendCmd(COMMAND cmd)
// combine pre data with specific code
irsend.sendNEC(PRE_DATA | (long)(tv_codes[cmd] & 0xffff),32);
// we must move deliberately to avoid missed clicks
delay(300);
which is called, for example, like this:
sendCmd(up);
Thank you very much! That is exactly what I was looking for.
