File > Preferences > Show verbose output during > compilation (check) > OK
Compile a sketch that includes the library
After compilation finishes, examine the contents of the black console window at the bottom of the Arduino IDE window. You will need to scroll up to see it all. Somewhere in that output you will find the path to the library. Note that in some cases that path may be in a location that your operating system tries to hide from you by default.
Here's the easier way to do it:
File > Examples > select one of the examples for the library you want to find
Sketch > Show sketch folder - This will open the example sketch folder. Navigate up two folder levels to reach the root of the library. You may find the library source files in that location or they may be in the src subfolder.
Thank you! I found the directory after some searching using the harder way:)
