Where to get 4-digit 7-segment LED with decimal points and colon 0.56" digits?
I have a design that needs 4-digit 7-segment LED with decimal points and colon 0.56" digits. I looked on ebay and there seems to be only 2 sellers that sell these (yeah, some are aliases of the same sellers). One has the wrong connection diagram. I got a sample from them and the decimal points don't work. The other seller doesn't even offer connection diagram and just claims all the dots work. Should I trust them? I also looked at digikey and sparkfun but they don't have large enough digits. If you have used such display (both decimals and colons have to work), can you suggest a source of this display? Thanks.
My only one suggestion received from GoForSmoke:
This is common cathode and there's only one color so I wonder if there are other ones and common anode ones out there I just don't know. Thanks.
These ones look pretty close:
Just a bit small. I will have to use them if I can't find the larger ones.
Pretty hard to find the colons, I've spent more than a little time looking myself. Tayda sells some that are visually almost identical to those that Sparkfun sells, but the connection is just a bit different, and they're common cathode. But like the Sparkfun displays, they are 0.4". Both are good quality displays, very crisp and they don't need a lot of current.
I'd really like to find a part with six digits or more so I could have 88:88:88, etc., but they just don't seem to be out there. A two-digit part with a colon would also work by stacking them.
Let us know if you turn anything up.
Will do. If I find anything useful, I'll post where I get them.
these LED Display 7 Segment 4 Digit 0.56 inch Common Anode Ultra Red 21937ucd might fit what you need.
http://www.satistronics.com/10pcs-056-inch-four-digital-led-display_p1477.html
Can select common cathode or anode too when purchase. But only red.
Check out kingbright LEDs.
http://www.kingbrightusa.com/category.asp?catalog_name=LED&category_name=KC4-Digit+0.56in&Page=1
Whole series of common anode, common cathode, different colors.
