I currently have only about ten resistors of each order of magnitude from 10R to 1M, with a few scattered other E12 series values in between. I'm looking for a good source of resistors, preferably in packs of ~500-1000 assorted ones in sizes along the entire E12 series (though with a few more in more common sizes), ranging preferably from 100R to 10M at least. Does anyone sell such a set? Or if not, does anyone sell single resistors for about $0.01 each? Other than futurlec; I've seen the reviews they have and I'd rather not take my chances.
hi,
you can get a set 4300 resistors at 86 values for <$30 on amazon:
http://www.amazon.com/Full-Range-Resistor-86x50pcs-4watt/dp/B00689SPV8/ref=sr_1_1?ie=UTF8&qid=1340237235&sr=8-1&keywords=e12+resistor
or 860 resistors for <$13 on ebay:
http://www.ebay.com/itm/1-4-Watts-Resistors-E-12-Series-86-Value-Assortment-Kit-0-to-10M-OHM-/400281118510?pt=Vintage_Electronics_R2&hash=item5d329d272e#ht_5500wt_1163
Taydaelectronics has resistors for $0.01 each and you can mix and match as you need.
even radio shack has a decent mix bag (500 for 13 bucks)
Thank you jaredpi! That 4300 resistor pack, while a bit excessive, is priced so low I can't pass it up! Plus they're metal-film too; I'll definitely be recommending this to others.
