Where to start a bit help would be great
I'm totally new to this and really excited about starting but have no idea where to start
What I'd like to do is built a small GPS data logger that can fitted to a hardhat so I can collect data (Its data fro a data location experiment)
Any suggestions where to start, this is what I am looking at:
GPS Module - https://core-electronics.com.au/adafruit-ultimate-gps-breakout-66-channel-w-10-hz-updates-version-3.html
Then use the Arduino Uno
Then follow these instructions - Logging GPS Data to an SD Card with Arduino - YouTube
Can you tell me if I'm on the right path?
That is the easy part. Powering the system for any length of time is the hard part. Add up all your current requirements multiply by the time and find a battery to put in your hard hat that will supply that power for the necessary time.
Most all GPS and all SD cards are nativly 3.3V supply and logic.
So if you want to use them with a 5V Arduino UNO you need to be sure all the GPS boards and SD card boards you are using are suited for use with the Arduino UNO.
Myself, I have done a fair bit of stuff with GPSs and SD cards, including loggers, but I always use 3.3V Arduinos such as the 3.3V Pro Mini.
Your very unlikley to be able to build a 'small' GPS logger for a hat with an Arduino UNO.
Thanks for replying
In terms of size what would you recommend so it can be fitted to a hard hat?
Is there a solution to making it smaller? I could also put it on a belt - they main thing it can't be obstructive
3.3V Arduino Pro Mini, not many Arduinos smaller than that.
srnet,
I've read that since the Pro Mini does not have a USB port it draws less current than say, a Nano, at all times (I mean whether or not there are any comms taking place thru the USB).
Is that right and is the current savings significant?
I found the Pro Mini awkward to work with as it can't be programmed thru a USB port. Next time I want to use a Pro Mini I think I'll do the development and testing on a Uno or Nano and commit to the Pro Mini when the program is proven.
You use a standard USB to serial adapter and plug it into the connector on the end of the Pro Mini.
Why is that in any way akward ?
I wasn't doing it that way. I used the RX/TX pins of a Uno. That requires pressing the Pro Mini reset button at just the right moment. Will try your method next time.
What about the current issue? Would a Nano use significantly more current than a Pro Mini just to support the USB port?
I dont have a Nano, being 5V its of little use to me.
Considering there is a GPS and SD card bing used, I doubt the extra current the Nano would use will have a big impact.
