I've been using an arduino for a while. Gotten alot of useful javascript experience.
Allthough, to me this is a rather limited language, and I don't really imagine it being a good interface to communicate with an Arduino or microcontroller via pc.
Sure, the Arduino could run Javascript, but I don't want to have to be running "Processing" (as I have so faar) or similar to get some sort of input/output option.
So I aquired Visual Studio. Unfortunately, I don't know where to start.
Is Visual C a good language to learn for this? And if so, where do I start with this?
c or c++ is better (more used), but don't bother yourself with it if you need a GUI.
also wiring is based upon this 2 languages, so it will improve your skill with arduino
Many of the examples for the Arduino are C, and you can code and use them directly from their tools (no Visual C needed). So if you wanted the greatest range of informaiton, C would probably be the best route.
If you want to use Visual studio to program applicatuins on the PC to communicate with Arduin, i would recommend c# (or VB.NET)
Most people use these two languages.
Doing serial communication with .net is relatively easy.
There are many examples in this forum and other places on the net, just google Arduino and c#
What I need is basically a GUI for my Arduino. Though, I don't want to rely on others, so I need to make this myself.
I've been using processing, but this turns out stupid, cuz it runs ok as long as I'm running it in the processing program, but if I attempt to open the java file I've made directly, It will open in my browser and be all fucked up. (Meaning indicators mostly doesn't work)
Impervium:
Ok, so if I use C, where do I start with this?
you can't open the java file directly. first of all a java file is lice a c file, just code. You need to compile it and then you have .class file. Now you can run it doing "java MainClassName" form terminal. Then you can put all file in a jar (processing can do this automagically), and if you open this .jar with java -jar JarName it will run exactly as a .exe .
actually java and processing (processing is not java, but a layer over it) are easy in GUI and use standard library in the API. never work with c# or .NET, but i don't think their GUI are portable over different system..
I've actually just aquired an ethernet shield for my arduino, so now I'm going to start making a GUI for communication over ethernet.
( I've previously made one for communicating over ethernet and through USB) :
Arduino - - PC #1 - - PC #2
Though, this GUI basically sucked as it was Javascript and I didn't know then what you told me now.
Now I intend to just run
Ardunio - - PC
and in the long run:
Arduino - - Internet router - - Internet router - - PC
I'm aware that Javascript is NOT Java.
That being said:
I've already done a test with a Arduino -> (USB) -> PC -> Ethernet -> PC.
This worked out OK, but the GUI sucked ass cuz on PC#2 I run it through a browser.
Now I intend to do a more advanced test.
I know about the IP and Firewall issues, I'm not completely green with this, I'm gonna use NAT to route some ports to a specified IP on an internal network on both sides. Also make a firewall exception if needed.
Though, what I'd really want (and haven't tried yet) is to have the target IP resolved by DNS.
Thereby having the host PC connect with some opendns, so I can autoresolve IP adress from the client.
But this is further down the road.
If you are concerned about real-time processing and memory management. C is going to be better than C++ because you don't have the overhead of "processing" all the Object Oriented "stuff".
