HI,
long long story -----> short story,
I have this code, to turn on /off things at home remotely. modified.
my issue is that I need to have my switch 4 to turn on only for 1 second to open the garage door. I have written and have put down “delay(1000);” after the command but it doesnt work. I do not want it to be on all the time it wont work the the garage switch, it just needs to give a 1 or 0.5 second of impulse to open the door. what am I missing or doing wrong. I have erased the delay(1000); command in this one posted. Please help.
#include “SPI.h”
#include “Ethernet.h”
#include “WebServer.h”
static uint8_t mac = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
static uint8_t ip = {
192, 168, 1, 69 };
// process post data here
if (type == WebServer::POST)
bool repeat;
char name[16], value[16];
do
repeat = server.readPOSTparam(name, 16, value, 16);
if (strcmp(name, “Relay1”) == 0)
if (strcmp(value, “0”) == 0)
digitalWrite(2, HIGH);
else if (strcmp(value, “1”) == 0)
digitalWrite(2, LOW);
if (strcmp(name, “Relay2”) == 0)
digitalWrite(3, HIGH);
digitalWrite(3, LOW);
if (strcmp(name, “Relay3”) == 0)
digitalWrite(4, HIGH);
digitalWrite(4, LOW);
if (strcmp(name, “Relay4”) == 0)
digitalWrite(5, HIGH);
digitalWrite(5, LOW);
while (repeat);
server.httpSeeOther(PREFIX);
return;
server.httpSuccess();
if (type == WebServer::GET)
P(messagestart) =
“Power Control Page”
Power Control
P(messageend) =
server.printP(messagestart);
if (Relay1active == 0)
if (digitalRead(2) == 0){
server.print("
server.print(R1text);
server.print(" - is On
else{
server.print("
server.print("- is Off
if (Relay2active == 0)
if (digitalRead(3) == 0){
server.print("
server.print(R2text);
else{
server.print("
if (Relay3active == 0)
if (digitalRead(4) == 0){
server.print("
server.print(R3text);
else{
server.print("
if (Relay4active == 0)
if (digitalRead(5) == 0){
server.print("
server.print(R4text);
else{
server.print("
server.printP(messageend);
server.httpUnauthorized();
void logoutCmd(WebServer &server, WebServer::ConnectionType type, char *, bool)
P(logoutMsg) = “
You have been logged out!
Goodbye
”;server.printP(logoutMsg);
if (Relay1active == 0){
pinMode(2, OUTPUT); //Set pin as output
if (Relay1state == 0){
else{
if (Relay2active == 0){
pinMode(3, OUTPUT); //Set pin as output
if (Relay2state == 0){
else{
if (Relay3active == 0){
pinMode(4, OUTPUT); //Set pin as output
if (Relay3state == 0){
else{
if (Relay4active == 0){
pinMode(5, OUTPUT); //Set pin as output
if (Relay4state == 0){
else{
Ethernet.begin(mac, ip);
webserver.setDefaultCommand(&defaultCmd);
webserver.addCommand(“index.html”, &defaultCmd);
webserver.addCommand(“logout.html”, &logoutCmd);
webserver.begin();
webserver.processConnection();
