Wheres the Analog in or (A0) pin
Wheres the Analog in or (A0) pin on the arduino esplora??? :slightly_smiling_face: :slightly_smiling_face: :slightly_smiling_face:
I think it's used as an output to address the analogue mux.
Thanks but all ready using the Uno.
Legoman39: Thanks but all ready using the Uno.
I don't understand.
I'm just starting to use the Uno, if that makes more sense
Legoman39:
Iā€™m just starting to use the Uno, if that makes more sense
Not really, considering that you are posting in the Arduino Esplora forum, which is a very specialized Arduino board (and quite different from an Arduino Uno)ā€¦ :confused:
Ralf
what i'm saying is when I posted it I was using arduino esplora then I started using the uno because I didn't think there was a A0 pin on the esplora
You've switched over to the Uno, but in case anyone else is reading along, the Esplora has two input pins available as described at the following link
http://21stdigitalhome.blogspot.com/2013/03/reading-arduino-esplora-tinkerkit-inputs.html
