I'm designing a small simple project that accepts two linear 0-5v input and then outputs a bent 0-1v signal as a result.
It will be going in a car so I am looking for a board I can buy that is already assembled and has a nice box with terminal screws already mounted. I could accept no box and just terminal screws though.
What products are available that might suit my needs? I'm quite an experienced programmer I just am not familiar with the various ranges available.
In case anyone is interested the project is to convert a wideband AFR signal to a narrowband signal to convert a car to "lean burn" by effectively creating a narrowband sensor that swings around a configurable AFR range. The second analog input is for rpm so I can implement other fancy stuff down the track.
