Im going to make an X-Y plotter by using 2 Stepper motors to control the X and Y axis, as well as a solenoid to move the pen up and down, ofcourse i would like to just input a sketch on a PC and let the XY plotter draw it. I wish to use an Arduino to control the power input to the 2 Stepper motors (turn them on and off) The Stepper motors that i am going to use have the following specifications...
Company: VEXTA (stepping motors)
Model: PXB44HZ-02AA-C8
DC 6V SR7 0.8 A 54354
2-phase 1.8degrees/step
the first question i have is...
My first worry is how does the Arduino power up the 2 stepper motors? To my knowledge I will need 2 PWM pins to power the 2 stepper motors and 1 for the solenoid, but will it provide power through the PWM pins, or does it produce a signal to turn on an EXTERNAL power supply which then powers the motor? (PLEASE correct me if i am wrong, i have been reading from nomber of sights and the information might be jumbled up in my head)
I assume that i will somehow need to convert the CAD picture (or sketch) into Code, which i can then send to the Arduino to input the necessary power to the motors, and I assume that this is taken up by the Flash memory of the Arduino (agian Please correct if wrong), How much Flash memory do you think this will take up?
I think that the information is jumbled in your head. The Arduino board will NOT power the steppers. You will need a stepper driver or shield. The easiest method is to have something like this: https://www.sparkfun.com/products/10267
You won't get much of the picture into RAM because there is very little RAM in an Arduino. You will need some CAD program running on a PC to do the conversion. I would suggest to Google Arduino CNC or something similar.
Am i missing something that is blatantly clear?
This is not a trivial project. I suggest you do a lot of research. If you are new to Arduino, I suggest you start with a simple task and work your way up.
I know you guys get this question 10 times a day but your help is greatly appreciated .
An Arduino UNO will be a good starting point. There are tons of examples and libraries. I am also 99% sure that an UNO will be enough to accomplish what you are trying to do.
