Hi there,
i want to build myself an arduino driven pressure and temperature logger to use while scuba diving. It should have the following features:
-Turn on automaticly when i get into the water
-Adjust the pressure sensor (so it gives correct readings no matter what alttitude I dive in) when it powers on.
-Log time, temperature and pressure on an SD card
-Flash a warning LED when the temperature drops below 6°C
-Turn back of after getting out of the water.
and could be done on every arduino i think
as for powering on/off - not really sure how to do it - you could get the altitude reading from the pressure sensor and based on the altitude turn the device on/off but it maybe harder than it looks cause the altitude reading its based on the see level pressure and i think the pressure will change with your altitude so the calculation may not be so exact
but one question putting the sensor (pressure sensors) in an airtight case will not cause problems ?
also if you want a smaller data logger check this out SparkFun OpenLog - DEV-13712 - SparkFun Electronics
Have a look at Seeeduino's Stalker.
It's a Arduino especially for data logging. Its have at on-board SD card slot, a RTC chip and a on-board temperature sensor.
Actually they do also have a temperature data logger example code on there website. So with some mirror changes i think it could be a good starting point for your project.
Check with member Packhorse (in new Zealand) too - he is working on a similar device already. I think jest need to add an SD driver/socket to it, like the functionality of the adafruit shield.
Ok, thanks for the replies. I had a look at Packhorses project and i think that with some slight modifications I should be able to turn it into what I want
About the pressure sensor: I think Putyn is right about the sensor in an enclosed case. Will try to think of something to do about that...
As well as reading the pressure inside a pressure sealed box your requirements pose a few other challenges.
Seeing the warning LED through the aluminium is going to be tricky. Reading the temperature through the metal should be possible but the reading will be delayed. Getting the processor which is off to detect when the dive starts and turn itself on seems to need time travel (okay you could have some electronic circuit that switches the processor on when electrodes get wet, but that's making things complicated). Reading the surface atmospheric pressure, to adjust for altitude, after the dive has started also needs a bit of time travel.
I think life would be a lot simpler if you just turned the thing on/off manually.
Take a look at your depth gauge. I imagine it is liquid filled and has a transparent face which, when pressed, causes the pressure reading to change. You might want to consider if you could do something similar putting the arduino inside a container filled with inert non-conducting liquid, flexible transparent front to transmit pressure and allow led to be seen, thin metalic foil transmitting heat from exterior to temperature sensor surface.
Some dive watches are liquid filled. I bet that some dive computers are too.
