Which Arduino will I need?
Hello!
I'm making a project which will require 6 servo motors and a 3x4 keypad and perhaps some leds. As i understand it, the keypad is connected to analog inputs and servo motors to digital? Which brings me to my question..which arduino do i at least need to have enough pins? (i want the one which is the cheapest)
Thanks a lot! :)
if you are new to Arduino the Uno is probably the best board to start with as it is the most standard and therefore the easiest to get help with.
It should be quite capable of doing what you describe.
When you have your project working (and know a bit more) and if it is to be a permanent project you might decide to move it to another Arduino board and release the Uno for other projects.
...R
