I don't think button cells can provide anything close to enough current.
You can get small LiPo cells - a single cell produces 3.6v. However they can go on fire if they are not charged carefully. HobbyKing's website has a lot of them.
Apart from that you probably need to use regular Alkaline of NiMh cells.
Robin2:
How many amp-hrs does your project need?
...R
You're right and I'll try another approach.
This board is to impress someone and it was intended to be used without any external power supply. The idea was wrap the package and see it working
So, I really needed a cheap/small/slim solution, however powering up a board like this is impossible with coin cells.
The solution I decided is using an USB plug into the board and power it up using an USB port.
Let's see if this solution creates the impression I want to.
