Which Bluetooth Module/Shield should use?
Hello,
This is my first time working with Bluetooth, so please bear with me if I ask any stupid questions here.
I have finished my lighting control device that controls light intensity by using Arduino Uno sending desired control signals (8-bit numbers) to program a PWM LED Driver (TL59731), which set the light intensity at wanted levels. Right now, in order to adjust the light level, I could either hard-code into my code or sending 0-10V control signal via an analogPin of the Arduino.
So now I want to advance my project by sending desired light levels (as 8-bit variables) into the Arduino Uno from my phone (Android) via Bluetooth protocol. Since there're so many Bluetooth Modules selling on the market, I really don't know which one I should buy and try. Some of my thoughts on the Bluetooth Module:
*Energy consumption is not my problem so I could use BLE or any *Distance is not my priority, but I hope to send data within 10 meters, so I should use class 2 Bluetooth? *I am a beginner in Android Developer so my ability to code in the platform is limited. If the module has an open source code/app that I can use for testing would be a plus. *Last but not least, budget is not my problem
I been reviewing the BlueFruit LE Shield Bluetooth Shield but unsure if it's a right fit.
Do you have any thought/ advice for me?
Thanks,
The older technology is HC-05 module.
The new technology is HM-10 module.
You would consider BLE if energy IS a problem, but I think you should consider it anyway. BLE is the way we will all be going.
No. You can but not should. A BLE device is just as useful over short distances, and more likely to get through walls etc.
It doesn't, and doesn't need to. You may want to configure the module but may never actually need to. It is just a means of transmitting serial data that is a substitute for two bits of wire. There is no need for any special Arduino code either. It just talks to a serial port and neither knows nor cares if a bluetooth is connected to the other side. I assume you are developing an Android app for a unique need or just the intellectual execise, but you might check the excellent apps that are already available before you re-invent the wheel. One of the biggest threads on this forum is bluetooth joystick.
Well, it's a relief to hear that you have lots of money. That might mean you can afford $3-28 for an HM-10, or even one of those things from Adafruit.
The above presupposes the phone has BLE. If it does not your BLE module reverts to BT2. This would not be a reason to get a BT 2.
