Which board should I use?
Hello!
I'm planning to buy an Arduino board. But I have some questions.
I'm a C++ programmer, really interested in computer hardware. I made some blueprints of actual processors and other electronic components, and now I want to use real hardware.
I wanted to know the following:
  • What Arduino board will better suit my needs? (I'll probably use multiple Arduino boards in the same project)
  • Is there a full support for C++? (ex: can I write my own functions instead of writing everything in setup() and loop()? what about namespaces?)
  • Do you know where I can buy simple hardware (EPROM, resistors, LEDs, etc.) and ship the to France?
You are not writing about your needs so it is hard to say which board could fit. However I think, Arduino UNO is good for beginning. The price is not high even you buy genuine Arduino, if you decide later for other type.
EDIT: The UNO has a big advantage in removable chip in case of its damage.
There is full support of C++. You can write your own functions instead of any Arduino function. If you are experienced programmer, it should not be a problem.
I do not know about your location and electonics shops near to you but everything is able to buy over the internet.
...and welcome to the forum!
Couple of distributors to France:
http://radiospares-fr.rs-online.com/web/
@CrossRoads thanks for the links!
@Budvar10 I'd use Arduino mainly for logic simulations, the board will be connected to LEDs and switches, and will host an ALU emulator. It will probably be connected to other Arduino boards (if I hit the memory limit) or used in larger projects with multiple EPROM chips and LED matrix. (but in this case I'll purchase a second board if needed)
Heuh tu fais gogole "distributeurs arduino" et tu en as plein d'autres nettement moins chers dans les frais annexes que ces deux là qui sont spécialisés dans le professionnel.
Lextronic
Nasser Fatiha
France Robotique
Emotion Tech
A4 Technologie
Multipower
Avro Tech Lefabshop
Matlog
Semageek
E44 Electronique
Snootlab
Selectronic
Go Tronic
Atlantique-Composants
3sigma
Letmeknow
Holdelec
Generationrobots
Arobose
Evola
L'impulsion
Etoele
Zartronic
Tu sais tu peux venir chez nous, il y a des bons aussi.
http://forum.arduino.cc/index.php?board=33.0
