Hi friends !
As my name suggest, I am an absolute beginner.
I have a AC Motor. And there is no capacitor build on.
You can see the motor details on the attachmend of this post here:
Hi friends !
Why do You want a capacitor on that 3 phase motor? What would it be supposed to do? Where would it be mounted?
it is listed on eBay. I asked the seller whether a capacitor is needed, or not. He than said, that this motor do need a capacitor because it is a 220V motor. Maybe he is a beginner too :DD ?
Beat me to it!
The OP does not realize the "3 tilde" means three phase.
Paul
by the way, I just read on google, that 3 phase motors actually do need capacitors.. now I am confused ![]()
NONE of ones I have had!
Paul
I think the seller is a 9 volt PP3 guy...
What kind of 3 phase main do You have available?
If it is 380 volt, phase to phase, You use the Y- type of connecting to make the motor windings get 220 volt.
If it is, if it exist, 220 volt, phase to phase, You use the delta connecting.
what do you mean sir ? does the motor need a capacitor or not ? so help me please.
That makes us 2.
you need VFD to 3 phase motor use. ![]()
what do you mean man ?
what do you mean ?? please help.
So help me falks... if i would connect it to a 220V connection, do I need a capacitor ?
ist jemand aus deutschland hier ?
Where does this motor come from? I Googled T56B2T but got nothing at all.
Thinking again this motor might need a 3 phase of 220 volt, phase to phase. In that case 380 volt mains can't be used at all.
Can You post a picture of the connection box on the motor?
no, it is listed on eBay. maybe this helps you ?
Um Deutche Freunde zu ansprechen verwenden Sie den Deutchen abteil von Forum.
does the photo helped you ? I just have requested a detail photo of the cable housing... so therefore we must wait for the photo first ;D
No. I thought the motor was available at Your desk.
What I search is a picture into the connection points, the place where You connect the power cables. I'm not sure it will solve the matter.
okay, sir. as I said above, we have to wait of the picture from the eBay-Seller. I just asked him for a picture from the insight. I will post it here as soon as it is available. thanks man. (Danke).
