which driver should i prefer
hey there!........i am using NEMA 23 stepper motor for my project, but i can't decide which driver should use?
here are some spec. of motor
Voltage : 12-36V
Current : 3.2 A DC
Torque : 10.1 Kg-cm
Step Angle : 1.8 deg / step
i tried A4988 but it get damaged as its operating current is 2A. I am using 12V 3A power supply.
It's hard to damage an A4988. It's a current-limited driver so using a 1A driver on a 3A motor is OK. Ordinarily, yes, a 3A motor would destroy a 1A controller but not in this case.
Stupid things like unplugging the motor while it's powered up are usually what destroys those chips.
You just need to find a 3A controller. Google isn't working today? A larger controller may be used but only if it has an adjustable current limit.
For that motor I would use a driver that can handle 4 or 5 amps to provide a little headroom. Unfortunately they are a lot more expensive.
An A4988 can only provide a bit more than 1 amp without overheating.
...R
Stepper Motor Basics
Simple Stepper Code
is L298N or DRV8825 will be good????....... if i run the motor on 2A instead of 3A.
will it affect the motor motor torque or speed?
The L298 is totally unsuitable - it is intended for DC motors.
A DRV8825 will probably struggle at 2 amps and your motor torque will be significantly reduced. Presumably you chose that motor because your project needs the torque so at lower currents it may not work at all.
...R
