I need to use netduino plus with secondary ethernet.
Which choosen ethernet shield (below links or another)? I use .net microframework, I need to choosen shield c#/vb library or native dll.
Secondary ethernet only, listening tcp packet and send/receive data. Maximum byte process to be important.
Thanks for advice.
If you use SPI...
This is the one to get. Do take note that it is not a shield... you still need to connect wires to your main board.
The reason for this choice is that apparently the W5300 uses external memory interface only.
I use the shields with Netduino plus, don't need wires or mainboard.
I think it ; Netduino + ethernet shield. Maybe use secondary ethernet.
Crossposted AND offtopic. The netduino forum is down the road a ways.
