Which Ethernet Shield
I need to use netduino plus with secondary ethernet.
Which choosen ethernet shield (below links or another)? I use .net microframework, I need to choosen shield c#/vb library or native dll. http://www.sparkfun.com/products/9472 http://www.sparkfun.com/products/9473 http://www.sparkfun.com/products/9474
Secondary ethernet only, listening tcp packet and send/receive data. Maximum byte process to be important.
Thanks for advice.
You didn't describe what your projects should do so it is difficult to advise you,
Have you read the comments below the articles? imho there is enough info in that to make a choice ...
My personal choice would be - http://www.sparkfun.com/products/9473 - 9472 seems difficult to get started. 9474 seems to be an HTTP only server. But that's my choice -
I try to my project ;
First ethernet (on the microcontroler) will be only, listening tcp packet and send data. Secondary ethernet (on the shield) will be only, receive & process data.
I replied on this thread:
http://arduino.cc/forum/index.php/topic,65402.0.html
and I'll reply again... if you use [u]SPI[/u] to connect to the Ethernet board, then the way to go is with the W5100 chip. If your NetDuino has (IT DOESN't) an external memory bus with all the correct signals, then you can use the board with the W5300. Otherwise, you are forced to use SPI to interface the chip, in which case only the board with the W5100 chip is usable (http://www.sparkfun.com/products/9473).
Got it?
If you read through the comments on both W5300 boards, you'll see one or two comments complaining about it.
I think you want to head down the road to http://forums.netduino.com/ They don't answer Arduino questions over there...
