I need to exite two sensors with 2.5 Volt, delay for 10 MS measure and send the data via and SMS to server every 6 hours. Also need to go into a sleep mode between measurements to save battery life and measure a flowmeter pulses (switch closures) in die sleepmode.
The flowmeter output is a switch closure from a plastic kent flowmeter and the two other sensor specs is:
MEASUREMENT TIME
10 ms (milliseconds)
OUTPUT 300 - 1250 mV, independent of excitation voltage
OPERATING ENVIRONMENT
POWER REQUIREMENTS 3 VDC @ 12 mA to 15 VDC @ 15 mA
You did not post a link to the datasheet so I don't know what "measurement time" means. But it looks like yhe Arduino just needs to read the voltage which should not be a problem.
I had missed the point about counting pulses while asleep. I think you can arrange for the pulse to wake up the Atmega 328 from sleep. Do you know the width (in microsecs) of a pulse ?
