Which home automation platform ?
Hi all,
I have a number of HDL-BUS devices installed at my house and I have designed and developed code for additional ones based on the arduino platform. The protocol is open source so its possible to everyone to design compatible devices.
I am now looking for a compatible central automation software to integrate everything in a nice looking dashboard. I ve looked at domoticz and openHab but it seems that neither has builtin support for my system .
Anyone know of any other platforms that either support HDL BUS or its easy to add support by defining the protocol?
Thanks!
Sorry, your link to HDL-BUS protocol does not work. Where can I read about HDL-BUS?
See attached file.
Do you also have smart. Bus devices?
SMART-BUS Protocol V1.4.pdf (143 KB)
Watcher, thank you for the info. No, I do not use Smart Bus devices, just curious about its protocol. I think RS485 is not the best choice for home automation.
akouz:
If you can have cat5 cables routed all over the house, it works fine and its very reliable.
Its just difficult to retrofit on existing buildings.
Watcher:
I do have cat5 cables routed all over the house, but I refuse to use RS485. I prefer to use CAN transceivers instead.
RS485 is not suitable for CSMA/CA or even for CSMA/CD. RS485 transceivers diminish communication to "master-slave" paradigm. It is not good for home automation. CAN transceivers are suitable for CSMA/CA and for "producer-consumer" paradigm.
True. In my own implementation of the above protocol i have opted for a software version of csma/ca where the bus is sampled before transmission and if busy, transmission is delayed.
