Hi there, I'm working on with an Arduino Mega 2560 and a C5515 eZdsp (from Texas Instruments) for a college project and I'm connecting the two boards via I2C.
The problem is I can't figure out which I2C address I have to use.
The Arduino is the slave and the C5515 the master. I read values from a pots and buttons from Arduino and sent them to the C5515 when it requests it (so I use the onRequest() function).
How can I know which address can I use?
I have tried an I2c scanner for Arduino and the results were:
I2C device found at address 0x18 !
I2C device found at address 0x2F !
I2C device found at address 0x3C !
From C5515 datasheet, 0x18 is for his oled, 0x3C for audio and 0x2F is not specified.
So I tried some addresses like 0x2F but the protocol doesn't work.
But just to try, I tried the 0x30 address and it worked for a while with some inestabilities and stoped working.
Also, I saw this address table (http://simplemachines.it/doc/IC12_97_I2C_ALLOCATION.pdf) but I don't understant it ... is this table for a general purpose of i2c protocol or is for a specific board?
Thank you in advance.
