Which is better millis()or timer?
I want to create a 30 mint delay in my program(Arduino)
which is better millis() or timer for this purpose?
please give me an example to clarify my doubt ...
Thanks.
Do you want the entire program to wait for 30 minutes without doing anything* else?
Do you want to be able to read inputs or do anything else during this time?
If the former, just use delay().
If the latter, use millis()
*other than process interrupts, I believe.
  1. Do you want the entire program to wait for 30 minutes without doing anything* else?
no..along with i want to receive data from UART..
Continuously wait uart for recive data
Just use millis(). It's far simpler (in my opinion).
For example :
unsigned long chrono = 0;
const unsigned long duration = 30*60*1000ul; // 30 minutes in milliseconds
  chrono = millis();
void loop () {
  while (millis()-chrono<duration) {
    // do your UART stuff here
  // do the rest
lesept:
For example :
A WHILE loop blocks until it completes - even if it does things during the loop.
For more flexible non-blocking use of millis() have a look at how millis() is used in Several Things at a Time.
Note how each function runs very briefly and returns to loop() so the next one can be called. None of the functions tries to complete a task in one call. And there may be dozens of calls to a function before it is actually time for it to do anything.
And see Using millis() for timing. A beginners guide if you need more explanation.
...R
Here is a demonstrative sketch based on Post#4.
const unsigned long duration = 5000;//30 * 60 * 1000ul; // 30 minutes in milliseconds
  pinMode(13, OUTPUT);
void loop ()
  unsigned long chrono = millis();
  while (millis() - chrono < duration)
    while (Serial.available() > 0)  //enter characters from InputBox of Serial Monitor and then click Send button
      char x = Serial.read();
      Serial.print(x);
  // do the rest
  digitalWrite(13, !digitalRead(13));
