Which LED strip to get, and how to drive them?
This is a followup on my first post. I'm new to electronics and have only had my Uno for a few weeks.
For my first project, I'm doing custom lighting for my car. I plan to have an Arduino with a Bluetooth shield controlling an RGB LED strip in my front bumper. I'll be sending values for certain parameters (heat, intensity, hopefully speed, all in the 0-255 range) from an Android app I made (with Processing) that will run on my phone.
The code is somewhat processor intensive... it takes ~32mS for each iteration of loop() on the Uno, although I think there's still some room for optimization.
I've been researching LED strips. I want a 60 LED/meter strip because that gives me about 40 pixels in the opening. A 30 LED/meter strip doesn't have enough pixel density. I'm familiar with the difference between 2801 (has a separate clock line) and 2811 (shared data+clock), but I'm seeing conflicting information about whether an Uno can drive a 2811, especially considering how heavy my code is. I can't decide whether to use a 5V or 12V strip, I'd like them the be as bight as possible so that they cast light in front of the car that's decently visible on the pavement at night (no, I won't be driving with them on).
I simply don't know what the most efficient/effective method is to drive them: hardware SPI (software SPI is probably out), I2C, shift registers, etc. With what I currently know, I'm inclined to get 2801's just to avoid the timing issues, but I suppose any method will work as long as the LEDs latch their values until the next iteration. Improvements to the SPI libraries related to 2811's seem rather recent (the last year or so).
I want to achieve an iteration time of 50mS total (20 FPS) or less, which I can then slow via delay-like code using the speed value. Of course anything faster is a bonus. Or maybe I'm overthinking what needs to be done to send 120 bytes out to the strip for each frame. The limiting factor is the code that determines what those bytes are. I'm not totally married to the code, just to the effect it produces. If there's a faster code method I'm open to that too, such as cycling through Perlin noise, which according to some other threads here may be faster than what I'm doing.
Hardware SPI is almost certainly the fastest way of addressing the strips. There are no problems with hardware SPI that I know of.
You should be able to send a byte every 1.125 µS using hardware SPI, or around 888,888 bytes per second. Of course, deciding what to send will take time.
Right, I should have expected that answer. I'm having trouble finding a good resource on how to set it up, almost everything points to the FastSPI library.
FYI, I have a Seeed Studios BlueTooth Shield on the way, which I'm sure will dictate usage of certain pins.
I got one of these from Adafruit:
There was nothing to setting it up, you just hook up four wires, including +5V and Gnd.
You need to measure the distance between the two baffles where will u install the led strip light.Different led strip light,then different width of the PCB.And Pls check the the output voltage of the CAR INVERTER.
