Which Library for Time operations?
Hallo, I want to run code like this:
  if ((hour() > 19) && (minute() == 0))
    digitalWrite(16, HIGH);
  if ((hour() == 11) && (minute() == 0))
    digitalWrite(16, LOW);
I tried to use timelib.h which doesn't work for me (I read the docu on github) because hour is always zero
#include <TimeLib.h>
  pinMode(16, OUTPUT);
  Serial.println("The time is:");
  Serial.print(hour());
  Serial.print(":");
  Serial.print(minute());
  if ((hour() == 20) && (minute() == 0))
delay(30000);
and RTClib.h which seems to need tons of code which I don't understand.
Is there an easy way to read the hour?
Do you have a RTC chip ?
No (I use an ESP8266 board). I guess I have to read the time via Wifi, right?
If you have an ESP, the official time library is already available, and it's preferred. It will save you a lot of headaches to use it, it handles NTP itself too. Check out your ESP libraries, there are example sketches there like "SimpleTime".
I got it with the library NTPClient.h (official).
#include <NTPClient.h>
// change next line to use with another board/shield
#include <ESP8266WiFi.h>
//#include <WiFi.h> // for WiFi shield
//#include <WiFi101.h> // for WiFi 101 shield or MKR1000
#include <WiFiUdp.h>
#include <ESP8266WebServer.h>
const char *ssid     = "WLAN-MS";
const char *password = ".................";
WiFiUDP ntpUDP;
// By default 'pool.ntp.org' is used with 60 seconds update interval and
// no offset
NTPClient timeClient(ntpUDP, "europe.pool.ntp.org", 3600, 60000);
// You can specify the time server pool and the offset, (in seconds)
// additionally you can specify the update interval (in milliseconds).
// NTPClient timeClient
  WiFi.begin(ssid, password);
  while ( WiFi.status() != WL_CONNECTED ) {
    delay ( 500 );
    Serial.print ( "." );
  Serial.print("Got IP: ");  Serial.println(WiFi.localIP());
  timeClient.begin();
  timeClient.update();
  int stunde = timeClient.getHours() + 1;
  Serial.println(stunde);
  if (stunde < 20 && stunde > 10)
    Serial.print("Should be off");
    Serial.print("Should be on");
delay(30000);
You are using a single & for a and. You need two of those.
if (apples && fruit)
if (pears and edible)
https://arduino.stackexchange.com/questions/85403/error-using-ntpclientlib-h/85405#85405
Thanks!
time.h uses that library and any functions that it needs from there. So you don't need it.
