Hi
I'm building a custom Temperature Logger, I'm going to use a standalone ATMega328, a DS1307 for timestampings, a DS18B20 as a temperature sensor and an eeprom for data storing (I will only save a few dozen readings each day).
I'm powering it with a wall adapter providing a 5v source (no battery) and I'm not using any sleep technique as of now but I'm willing to switch to a battery powered standalone device and a powersaving sleep approach in the future.
I was wondering which RTC library I whould use. I've seen a lot out there, the Adafruit RTClib and the JeeLabs RTClib, the ds1307 and ds1307new, the DavidHBrown RealTimeClockDS1307, the Turicas DS1307 and so on ...
I really need basic RTC interactions, no fancy stuff. I just need to read date/time from time to time (not constantly) in order to provide a timestamp to any temperature readings I'm going to save on the eeprom. I will also have to set a new date/time when needed. As you see, I don't need a full fledged RTC library, but I don't know all those libraries well enough to judge what is too much or what is not worth even trying out.
Which one would you suggest me to use?
I was just missing a detail ... I'm going to try and port all that to a smaller processor in the future, some ATTiny may be enough. I wonder if someone has already used the DS1307 with an ATTiny ... should work too
