Which mosfet do i need?
Hello :slight_smile:
I used the forum search but didnt found the thing i need.
My question is:
I use a lowpass filter to regulate 0-5 V from a PWM pin on my arduino micro.
Now i want to regulate with this 0-5V a 0-12 V circuit from a battery.
Like 0 V = 0V and 5V = 12V. (like rangemapping)
Can i archive this with a Mosfet? and if yes which one do i need?
thank you
In general analog signals are processed with opamps - but you haven't
said what the load is for the variable 12V signal - if any significant
power is needed a power amplifier may be needed.
But what are you trying to do in the first place?
Hey thank you for quick replay.
The load on the 0-12V side is about 3A i think.
Trying to build a power regulator for e-cigarettes :stuck_out_tongue:
thank you
Not sure if this helps but I was using a TIP120 transistor to power a 12v 4amp linear actuator from an arduino output pin. I just hooked the actuators positive wire directly to 12v 4amps and the negative wire thru the transistor (with a diode since it is a motor). They typically cost $1-$2 each.
