Hello,
I would like to use the data of an optical mouse sensor. I found this already: http://www.liubo.us/read-data-from-an-optical-mouse-using-arduino-and-processing/
But I want to found out which sensor is used in my mouse, but there's no indication of the type. It's a Toshiba PA3571E-1ETB mouse.
Thanks!
minitreintje
Are there any markings on the sensor chip?
There are no markings on the chip...
But the hole pattern is the same as a PAN3101 but I am not sure that the pattern a marking is....
regards,
minitreintje
Thanks! I will try it... I want to read out the data to control 2 servo's.
regards,
minitreintje
It could also be an Avago ADNS-2610, which appears to be pin compatible with the PAN3101 (the pattern also looks similar, perhaps it is a clone). The two chips may even be protocol compatible, so try Martijn's tutorial anyway.
The pcb tracks seem to support a pan3101 layout (or compatible)
