Which option is easier to read data from a sensor for the web?
Which option is easier to read data from a sensor for the web(is not local network)?
1 - Arduino + Ethernet Shield + Router 3g
2 - 3g + Arduino Shield
3 - Others
Thank you!
"Arduino + Ethernet Shield + Router" would be easy, but not sure what the 3G is used for.
danilovpm:
3 - Others
Thank you!
Depends on what you have already and what you are trying to achieve ?
If it is a single Arduino talking to the internet then an ethernet shield is the simplest and least complex. Are you trying to serve up web pages or use one of the external sites to graph info etc ?
What Arduino do you have ?
I have had some good success using Nearbus libraries with the Arduino - the examples are very easy to follow and will have you pushing data to the internet in no time.
If you want to get fancy you can then use their google connector to push stuff to google drive and into a spreadsheet for you to do whatever you want with this. They also have two way comms so you can send data back to your arduino and control it
Craig
