Which pins are I2C
This is a random question but i could not find which pins are the scl and sda
The core should create symbols named SDA and SCL so you could write a simple sketch and print them out on the serial port.
They should contain the digital pin number for these signals.
--- bill
depends on board used,
some boards allow to overrule the SDA and SCL
For the Nano ESP32, SDA=A4 and SCL=A5.
You will see this documented if you search for i2c in the Nano ESP32 cheat sheet.
