I am creating a motor control board which requires four PWM pins to control two motors. These pins directly control motor speed without using any kind of enable pins. Now the question is, which four pins should I use so that it does not conflict usability of other functions. My requirements are:
I need two interrupt pins for speed control which are Digital Pin 2 and Pin 3. So, using Pin 3 for PWM is out of question
Now I am left with Pin 5,6,9,10, 11. Which pins do I use so timers does not conflict with delay(), millis() and servo() functions as I require to use all three functions in the program as there are 2 servo pins for connecting servos.
Yes. I have an encoder module which requires two pins for each motor. However i need atleast one hardware interrupt pin to read each motor. So, does it mean i have no other choice?
Should i give up on speed control, or is there any other way out?
Use pin change interrupts, and use pin 3 for PWM. I generally prefer PCINTs over the INTn pins for hardware interrupts unless I have some specific requirements that preclude doing so.
IMO attachInterrupt is an abomination. I try to minimize my contact with it.
praveen_khm:
I had been assuming you have a simple revolution detector that only requires 1 pin per motor.
AFAIK the reason an encoder has two connections is so that you can identify direction. Presumably you know the direction of the motor and don't need the encoder to tell you?
However that is not the main reason for this Post. How many pulses per revolution does your encoder produce? And how fast will the motor be rotating - i.e. what is the max number of pulses per second that one motor can produce?
My concern is that if you have a lot of pulses per second the Arduino won't be able to keep up. With one or two pulses per revolution there should be no problem - and one pulse per rev should allow very good speed control.
praveen_khm:
Why do you need delay(), it is a blocking instruction, while the delay is in operation, ALL of your code will STOP.
Tom...
In this case, I need to poll the registers every time, or need to use two different ports for each motor. Using interrupts is much easy. If there is no other option, then I need to use this method.
You are correct. I need only one pin which will still be the interrupt pin. Since I have multiple free pins, I use the second one for detecting direction. Yes, I already know the direction, but using the calculation in interrupt routine is much easier.
I am using a motor that has a revolution of 320 per minute with 330 pulses per revolution.
At this moment, no. Its not there in the code. But I do not want to lose that option in case I require it. Timer is definitely used.
praveen_khm:
Is a digitalRead() really that hard? I never felt it like that. And then you say:
I think checking a pin status is easier than this, and anyway you shouldn't be doing anything more than strictly necessary in an ISR (so NO calculations more complex than increasing a counter or so - leave that to your loop() to take care of).
praveen_khm:
The Motor Specifications you have linked to are a little different
No load RPM (before gearbox):8000 rpm
Gear ratio: 51:1
No load RPM (after gearbox): 146rpm@12V
Encoder Resolution: 13 PPR (663 PPR for gearbox shaft)
At 146 rpm = 2.4rps and 663 ppr that gives about 1600 pulses per second and with two motors that means about 3200 pulses per second. If they were all evenly spaced that would mean about 312 microsecs between interrupts. That does not leave a lot of time for the Arduino to do other things.
...R
So, does it mean it's not a good idea to read the speed? Any suggestions and a better idea? I am more of a hardware guy and i need to design the board with these implementations. If things don't seem to work, i might as well skip reading speed and just make a motor controller. But having additional options is always a plus.
I am not saying "don't read the speed". I am just suggesting that the technology you are proposing to use for reading the speed may not be appropriate if it uses so much of the processor's time that it does not have enough time to do the rest of the stuff you want it do (which you have not told us).
Robin2:
...R
The microcontroller is basically used only to control two motors and two servos. Four additional pins are used for RC input. That's all the things this microcontroller does. Since i am still designing the board, i thought of adding encoder support which makes it a complete package. I am not sure what you mean by technology used. Do you mean the motor is inappropriate, or is there a better software solution? Or should i use any other method to read speed.
As far as this discussion goes, i have almost decided to give up on reading speed. Just checking if there is a last ray of hope.
Either ways, thank you for taking the time to help me.
