My guess is that you didn't "blow" any leds
I am still learning, but looking back on it, the GreenLed Datasheet on page 5 (or see attachment) says not to bend the wires on the led. The Blue led datasheet doesn't really mention the no-bending warning, but is it possible that maybe the bending is what caused the short? I threw the non-working led away, but I am starting to wish I had kept it laying around.
In the attachment, you'll see a picture of a led in a red box. That is what the led looked like when it quit working. Keep in mind, i'm new to this stuff, so i'm not an expert in troubleshooting. What may be common sense to someone that understands this stuff, isn't obvious to someone who is trying to learn.
All of your questions are the result of not understanding Ohm' Law. Learn it.
I'm trying to. I'm trying to learn Ohm's Law, how to read datasheets, and a few other things. I haven't been able to find any good self testing tutorials to make sure i'm on the right track, so i'm reaching out to ask people to check to see if i'm on the right track.
I'll tell you what's going through my head right now and maybe you can lead me in the right direction so I can figure it out myself. Looking at the blue led datasheet, i see the Forward Voltage is 14 V. Now the arduino only puts out five, but as alnath mentioned, you can use a transistor or a fet (included in the kit) to drive 5V to 12V, so maybe the led works in a similar way. Truth is, I don't know.
So using one of Ohms many laws, R = (Vs - Vf) /I at this point the formula looks like R =(Vs-14)/I. Now I also think that Vs is 5V. So the formula now looks like R = (5 - 14)/I. I am getting the gut feeling that I may be way off, but then again, the datasheet says the led has a Reverse voltage of 5V so maybe I subtract 5 from 14. Maybe that goes somewhere else. Right now I understand Ohms triangle law, (see attachment) but that's about my limit to what i'm confident in saying I truly understand. That's why I am asking for help.
So as the equation in my head goes(as of now) R = -9/I
I know a 220 ohm resistor is safe. so I think the equation looks something like this. -9/220 = 0.0409 A.
So if i understand correctly (which I'm really iffy of) the resistor I purchase needs to be able to "ENERGIZE" using .0409 Amps. But then again, as you mentioned which I understood prior to asking for help, the relay itself adds resistance. So theirs even more complexity of which I don't know how to approach the issue. You said I don't need the resistor now, so I'm wondering do I take out the 220 ohm resistor, and substitute the relays resistance in it's place? If so, that would change the .049Amp requirements, which is a factor in choosing the relay.
And BTW,
The word is "ENERGIZE" not "FLIP". At least make an effort to learn the proper nomenclature for
the technology you are "trying" to learn.
I will make an effort to try to remember and cite the "proper term" from now on. Between you and me, in my mind, i'm still having to translate Voltage is water level, resistance is the tap, the stream is the current, and power is the rotating turbine. Please bare with me.
AGAIN, read the datasheet for the relay.
The relay I will use, depends on the output from the led though. I'm trying to figure out which relay to get.
