do you think you can point out to me which timer i should use for the PWM, it is important for my application that i output a PWM frequency of atleast 100kHz with a resolution of atleast 100 levels (7ish bits)
Im also worried that i might choose a timer that is very difficult to activate the PWM (not a very adept at coding) . All in all i need 4 PWM pins , if possible they would be on a separate timer so the PWM is not synchronized, but its not really a necessity
also about sercom they are very many of them, how do i know which is the mosi, miso , and sclk of each sercom? which sercom is best in performance are they the same?
PA16 to PA19 would give you the four pads for SERCOM1 which can be configured for either SPI, USART, or I2C
PA0 and PA1 gets you two channels on Advance Timer2
PA22 and PA23 gets you two channels on Timer4
PA27 to PA28 gets you two channels on the Advance Timer 3
The timers on the SAMD21 is generally more complex than the ones you can find on the AVRs (Arduino UNO), thus should have no problems generating your required waveform.
Does this help? SAMD21-PMUX - Google Sheets
The "TC" timers are the relatively simple ones.
I don't have SPI specifically noted on there, but you should be safe assuming that you need all 4 pads of a SERCOM...
