Hello, I am a beginner of Arduino.
I would like to do a project that talking about the distance among 2 people (person1,person2) in a dark room.
If person 1 far from person 2, there will be a A sound.
If person 1 reach the ideal distance from person 2, there will be a B sound.
If person 1 is too close from person 2, there will be a C sound.
I would like to ask what sensor should I use? as the IR sensor/ ultrasonic sensor will detect the wall, but I just want to detect another person only. Can PIR sensor can reflect the distance in serial read?
if there are two Arduino Boards and one connect to transmitter and the other connect to receiver and different people carry each of the board, can they measure the distance between transmitter and receiver?
The most common way it seems to measure distance between two boards is to use an ultrasound signal and a radio signal. One board transmits the radio signal and the audio signal at the same time; the other board measures the difference between time of arrival. Radio is as good as instant; audio moves at a mere 330 m/s giving an easy to measure time difference.
Major complication: ultrasound transducers tend to be pretty directional, so if pointed in the wrong direction the signal is not received, or an echo is received and the distance recorded is not the actual distance. Aiming it at the other person while in a dark room may be a challenge.
The VL53L1X (and similar sensors) are also highly directional, and require you to point at the object you want to know the distance of, regardless of what this is (could be the wall, for example). Again the overall darkness may be an issue.
Probably your best bet for this project is to use a set of Pozyx sensors, then based on the locations of the two sensors calculate the distance between them.
