I need to buy a sensor and I have the chose between output signals. Excluding cost, what is the best to interface with an Arduino Due (is there a difference with an Arduino uno)? An analog/digital resolution of 10 bit is sufficient for my purposes but more is always welcome off course. I don't mind buying additional components and soldering a bit.
I have the choice between:
Potentiometer 1 k?
Voltage 0 ... 10 V (18V excitation required)
Current 4 ... 20 mA, 2 or 3 wire (12-27V excitation)
Voltage or current output, programmable (PMUV/PMUI)
A/D converted synchronous serial interface (SSI) (11-27 V excitation; 16bit resolution)
A/D converted CANopen bus (8-36V excitation)
pulse output (5V DC excitation rotary encoder 300 kHz max)
I have some bad experiences with the pulse output and the arduino mega (for some reason it didn't catch all the pulses). And besides, when I lose power, I lose the 0 point so this is not really an option.
I would have loved to get the SSI interface. Simple and easy... BUT it needs 11-27V excitation.. is there an option to convert this to Arduino like voltage levels?
Sorry, I missed the potentiometer (I just saw 32 v). It would seem to be the simplest by far. One end to 5v, the other to ground and the wiper to an analog input.
I just had a conversation with someone much more experienced with microchips and electronics then me and he advised me to go for the SSI interface. I probably need about 5-10m cable between the sensor and the Arduino in an area subject to quite a lot of interference. He said that analog signals tend to perform poorly and that it is best to convert to digital ASAP. A simple voltage divider would solve the issue of different logic levels. He did advise me to add a diode to protect the Arduino from overvoltage.
Given the distance and noise environment I would agree with your friend. I used the voltage divider method to level shift 5 volt signals to 3.3 volts for an SD card and it words well.
groundfungus:
Can I use a high speed optocoupler to achieve the same result?
