Hello,
I have an arduino project in which i use an arduino uno r3 , a gps+magnometer module which supports i2c communication and a bsfrance LORA32U4 II transceiver which has hardware SPI. I have set up a program from arduino that uses softwareserial library and what it does is that receives data from the gps module, sends them to the lora module and then checks if there is any data received from the lora module by stopping listening to gps and starting listening to lora. All these with uart protocol. So my question is, would it help to use other protocol like i2c for the same purpose, speedwise or if it is even possible using these modules? Because later i want to receive and send more data to the lora module and i don't know if the timings of softwareserial would suffice.
if anyone has time to burn here is the code :
// Arduino Uno
This sketch parses the incoming data from the gps to the arduino
and then sends them to the lora transmitter via serial connection.
GPS device hooked up on pins 2(rx) and 3(tx) and a HMC5883 Magnetic
Compass connected to the SCL/SDA pins.
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_HMC5883_U.h>
#include <stdlib.h>
#include <Servo.h>
static const int RXPin1 = 2, TXPin1 = 3, RXPin2 = 7, TXPin2 = 8, RPin1 = 4, RPin2 = 6;
static const uint32_t GPSBaud = 9600;
float gpslat, gpslon, newlat, newlon;
double course;
uint8_t sats, hours, mins, secs, day, month;
uint16_t year;
uint32_t startGetFixmS, endFixmS, i = 0, j = 0, k, angle;
static char varbuf[32], sendbuf[32], lat_arr[10], lon_arr[10];
bool received = false, newData = false;
// Assign a Uniquej ID to the HMC5883 Compass Sensor
Adafruit_HMC5883_Unified mag = Adafruit_HMC5883_Unified(12345);
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the NEO-M8N GPS module
SoftwareSerial s1(RXPin1, TXPin1);
// The serial connection to LoRa transmitter
SoftwareSerial s2(RXPin2, TXPin2);
Servo myServo;
Servo motor;
pinMode(RPin1, OUTPUT);
digitalWrite(RPin1, HIGH);
pinMode(RPin2, OUTPUT);
digitalWrite(RPin2, HIGH);
Serial.begin(GPSBaud);
s1.begin(GPSBaud);
s2.begin(GPSBaud);
myServo.attach(5);
motor.attach(9,1000,2000);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print(F(__TIME__));
Serial.print(F(" "));
Serial.println(F(__DATE__));
sensor_t sensor;
mag.getSensor(&sensor);
Serial.println(F("Debugging attached NEO-M8N GPS module and LoRa"));
Serial.print(F("Using TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
startGetFixmS = millis();
s1.listen();
Serial.println("Data from gps:");
if (gpsWaitFix(5))
Serial.print(F("Fix time "));
Serial.print(endFixmS - startGetFixmS);
Serial.println(F("mS"));
gpslat = gps.location.lat();
gpslon = gps.location.lng();
sats = gps.satellites.value();
hours = gps.time.hour();
mins = gps.time.minute();
secs = gps.time.second();
day = gps.date.day();
month = gps.date.month();
year = gps.date.year();
printGPSfix();
Serial.println("Sending data to feather...");
s2.print("<");
s2.print(gpslat, 6);
s2.print(" ");
s2.print(gpslon, 6);
s2.print(" ");
s2.print("Sat: ");
s2.print(sats);
s2.print(">");
startGetFixmS = millis(); //have a fix, next thing that happens is checking for a fix, so restart timer
Serial.print(F("Timeout - No GPS Fix "));
Serial.print( (millis() - startGetFixmS) / 1000 );
Serial.println(F("s"));
s2.listen();
Serial.println("Checking for new coordinates...");
static bool reading = false;
while (s2.available() > 0 && received == false) {
varbuf[i] = s2.read();
if (varbuf[i] == '<') {
reading = true;
if (reading) {
if (varbuf[i] != '<' && varbuf[i] != '>') {
sendbuf[j] = varbuf[i];
j++;
if (varbuf[i] == '>') {
received = true;
reading = false;
i++;
if (received) {
//s2.print("<Coords received!>");
for (k = 0; k < 9; k++) {
lat_arr[k] = sendbuf[k];
lon_arr[k] = sendbuf[10+k];
newlat = atof(lat_arr);
newlon = atof(lon_arr);
Serial.print(newlat, 6);
Serial.print(" ");
Serial.println(newlon, 6);
//Serial.println(sendbuf);
//Serial.println(j);
if (newData) { //if gps data received, calculate bearing
course = gps.courseTo(gpslat, gpslon, newlat, newlon); // returns course in degrees (North=0, West=270) from position 1 to position 2,
//angle = map(course, 0, 360, 0, 180); // converts bearing to servo degrees
//myServo.write(angle);
//motor.write(100);
Serial.println("Bearing: ");
Serial.print(gps.cardinal(course));
received = false;
i = 0;
j = 0;
memset(sendbuf, 0, sizeof(sendbuf));
memset(varbuf, 0, sizeof(varbuf));
else {
Serial.println("No message");
bool gpsWaitFix(uint16_t waitSecs)
//waits a specified number of seconds for a fix, returns true for good fix
uint32_t endwaitmS;
uint8_t GPSchar;
Serial.print(F("Wait GPS Fix "));
Serial.print(waitSecs);
Serial.println(F(" seconds"));
endwaitmS = millis() + (waitSecs * 1000);
while (millis() < endwaitmS)
if (s1.available() > 0)
GPSchar = s1.read();
gps.encode(GPSchar);
if (gps.location.isUpdated() && gps.date.isUpdated())
endFixmS = millis(); //record the time when we got a GPS fix
newData = true;
return true;
return false;
void printGPSfix()
Serial.print(F("New GPS Fix "));
Serial.print(F("Lat,"));
Serial.print(gpslat, 6);
Serial.print(F(",Lon,"));
Serial.print(gpslon, 6);
Serial.print(F("m,Sats,"));
Serial.print(sats);
Serial.print(F(",Time,"));
if (hours < 10)
Serial.print(F("0"));
Serial.print(hours);
Serial.print(F(":"));
if (mins < 10)
Serial.print(mins);
if (secs < 10)
Serial.print(secs);
Serial.print(F(",Date,"));
Serial.print(day);
Serial.print(F("/"));
Serial.print(month);
Serial.print(year);
if (mag.begin())
displayCompassInfo();
void displayCompassInfo()
/* Get a new sensor event */
sensors_event_t event;
mag.getEvent(&event);
/* Display the results (magnetic vector values are in micro-Tesla (uT)) */
Serial.print("X: "); Serial.print(event.magnetic.x); Serial.print(" ");
Serial.print("Y: "); Serial.print(event.magnetic.y); Serial.print(" ");
Serial.print("Z: "); Serial.print(event.magnetic.z); Serial.print(" "); Serial.println("uT");
// Hold the module so that Z is pointing 'up' and you can measure the heading with x&y
// Calculate heading when the magnetometer is level, then correct for signs of axis.
float heading = atan2(event.magnetic.y, event.magnetic.x);
// Once you have your heading, you must then add your 'Declination Angle', which is the 'Error' of the magnetic field in your location.
// Find yours here: http://www.magnetic-declination.com/
float declinationAngle = 0.081;
heading += declinationAngle;
// Correct for when signs are reversed.
if (heading < 0)
heading += 2 * PI;
// Check for wrap due to addition of declination.
if (heading > 2 * PI)
heading -= 2 * PI;
// Convert radians to degrees for readability.
float headingDegrees = heading * 180 / M_PI;
Serial.print("Heading (degrees): "); Serial.println(headingDegrees);
