Please check the example simple blink code below:
pinMode(13, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(LED_BUILTIN, LOW);
delay(1500);
I can't find any timer library to do the same thing.
All the lib I can find is to do the simple blink with the same interval but no one can perform different interval.
The only lib I can find which most fit my need is sstimer but lack of the on/off function, I can't control the timer manually ...
Any suggestions?
system
February 6, 2019, 3:54pm
2
Any suggestions?
Write your own.
Why you think you need a library to do a relatively simple task escapes me. Perhaps its because the task isn't nearly as simple as you think.
Start by making a list off all the things you want the library to do.
If you are convinced that you need to use a library then look at PinToggle library
PaulS:
Write your own.
I have wrote my own code and run perfectly, just wondering if someone finished the wheel that we don't need to build another one.
UKHeliBob:
Thanks you, I will check it out.
DrAzzy
February 7, 2019, 6:53am
6
Something like that is best handled yourself (no library) using millis() (see blink without delay example, or the "doing multiple things at once")
