HIGH has the value 1, LOW has the value zero.
Neither will ever equal 3.
if i take a do option i read
int ledPin = 4;
int buttonPin = 8;
int i=1;
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
buttonState = digitalRead(buttonPin);
while ( i == 3){
do
digitalWrite(ledPin , HIGH);
Again, you gave i the value 1, which will never be 3 either
i dont understand one push is 1 so 3 pushes is 3
int buttonPin = 8;
int ledPin = 4;
int buttonPushCounter = 0;
int buttonState = 0;
int lastButtonState = 0;
if (buttonState != lastButtonState) {
if (buttonState == HIGH) {
buttonPushCounter++;
delay(300);
lastButtonState = buttonState;
while (buttonPushCounter % 3 == 0) {
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
Here is your code after auto formatting (in the IDE, ctrl-t or Tools, Auto Format) and the extra white space removed. Is it not easier to follow?
int buttonPin = 8;
int ledPin = 4;
delay(300);
This code:
If the counter is a multiple of 3 write the LED HIGH, then right away write the LED LOW. The LED will not be HIGH long enough to notice. An if, else would be better there, I think.
i know i haave to use for my program a while function
so like when i push 3 times the led goes on and if i push again 3 times it goes off
I did make the program in a while function
[ltr][color=#222222][code]int buttonPushCounter = 0;
int lastButtonStatus = HIGH;
int buttonStatus = HIGH;
boolean ledStatus = false;
pinMode(8, INPUT_PULLUP);
pinMode(4, OUTPUT);
digitalWrite(4, ledStatus);
delay(100);
int count = digitalRead(8);
while (count != lastButtonStatus) {
if (count != buttonStatus) {
buttonStatus = count;
if (buttonStatus == HIGH) {
if (buttonPushCounter == 3) {
ledStatus = !ledStatus;
lastButtonStatus = count;
[/color][/ltr]
[/code]
