I'm not seeing the errors when I run your code, but try putting a small delay (delay(1)) after Serial.end(); There's a bit more overhead in repeatedly calling loop() then in a while loop (the loop() call itself is actually in a while loop of it's own). So there may be a potential timing issue there.
Why are you calling Serial.end()? Why are you calling Serial.begin() in loop()? Neither of those functions is quick/cheap.
There are, obviously, things that happen in main(), between calls to loop() that affect Serial. By not allowing the program to return to main, you prevent those things from happening.
jraskell:
jraskell, thank you so much. Always these little and simple bits that keep holding me up.
There was a post a few days ago about how Serial.end() has a small bug -- it doesn't wait for the last one or two characters to be sent before ending. That's probably the problem.
WizenedEE:
Thank you for the tip. That would make sense. Workaround is to add a delay. Atleast that's what's working for me atm.
bperrybap:
But if you simply moved the Serial.begin() to setup() and eliminated the Serial.end()
you wouldn't run into the issue.
--- bill
Yes, but then my Arduino project would fail. I'm beyond the point of simply printing out "Hello world..."
Huh? You are going to have to explain that one.
Why do you need to shutdown the USART continually re-initialize it?
Unless you using some deep sleep modes in the AVR
or you are doing something unusual like trying to share the UART pins with some other function or changing
baud rates on the fly, I see no need to continually call the code to re-initialize the USART, which has
to perform calculations and re-write clocking divisors, etc...
The reason you were seeing the corrupted transmission is because you were reprogramming the USART
clock registers while the USART was still transmitting.
This occurred because of the weak/poor code in HardwareSerial flush() and end() doesn't properly wait
for the last character to be fully transmitted.
It only waits for the s/w buffers to empty.
There can be up to 2 characters still remaining to be transmitted inside the USART after flush() or end() return
1 in the data register
1 in the shift register being transmitted.
If your code must really know when the characters are fully sent,
you must wait 2 character times after you call Serial.flush()
The delay time will be dependent on the baud rate but can easily be calculated.
In essence, the serial port needs to be active only when Processing communicates with the Arduino. At all other times the ports need to be deactivated because the Rx & Tx pins are needed for other duties.
